Roland Versacamm sp540i - Not printing teal.
3Sixty5Designs
Can not seem to get mt versacamm sp540 to print teal, Maybe other colors missing aswell?
Will post a test print and other pictures of whats happening. PLEASE HELP!!!
test print seems to be fine
im trying to print a bright teal and lime green, although it doesn't look like it in the picture of the computer screen. and the last picture is the actual print.
test 1.jpg 117444647_642827433297997_4072294661547305167_n.jpg 117595765_344552096727651_4958179397860337729_n.jpg
woolly
print the spot colour sheets using the profile and quality you need from versaworks then chose the spot colour then dial in the number very useful when chasing colours
MikePatterson
Head bathroom cleaner.
Your monitor is rendering in RGB and your RIP is converting RGB to CMYK. As stated above , print the spot color library from VW and choose the colors you want.
We design in CMYK so avoid color shifting as much as possible. We also have everything calibrated to work together. Your monitor will not be perfect match to print the printer but will be close enough. Also you have to design with the output in mind and not what looks good on screen.
