Question Roland VG640 scan motor replacement?
TheSigntists
Hi Team, my machine Roland VG 640 popped an errorcode 0040 0040. Then after cleaning rail and checking dampers, and firing up, it came up with service call 0360. I can't really find any info online about it nor here after searching for hours. If the scan motor has died, how easy are they to replace? All suggestions welcome. I'm in New Zealand.
Fernando M.
Hi. I have a vg-540 and got this replaced a few months after I bought it. Still under warranty. I really would like to help but found almost nothing online. What I would do is go here https://www.rolanddga.com/support
and try to get some help from them. If you can avoid buying the motor from them if needed to, you can find it on Ebay ships from China. The deal is replacing it after you make sure you need to...good luck.
cornholio
There is a glass encoder disc inside the motor that needs cleaning. You need to remove the side panel to be able to remove the motor. Once you have it out, you need to unsolder the PCB to be able to clean the disk. Resolder and replace and you are good to go again.
TheSigntists
So the motor won't need replacing? Really appreciate the response guys.
netsol
that kind of repair can be an exercise in patience, but, with the price of the motor, well worth it.
cornholio
These are brushless motors, that should make thousands of hours before they need replacement. I encountered quite many of them failing at 200-300h and after opening one out of curiosity, found some sort of haze on the encoder disc. I cleaned it with a bit of glass cleaner like Windex and tested the motor working flawless in our showroom machine.
These failing motors have only been seen in VG's. Not VG2 or VG3.
The Sign Goddess
Vinyl Slayer by trade
Our scan motor failed on our VG2, but it was a mechanical failure. Sounded horrible but no error messages.
