creativevinyl
Hi, I have a Roland VP540 that was working fine, I had to move the printer due to relocation and lost half of the blue print, after checking this was a manifold break so ordered those parts and replaced. When replacing i noticed that one of the head ribbon cables was not right the little blue hard plastic part came away, I had a spare but was too short, so tried to make a temp repair, it all looked good, the green light on the print head board didnt come on, removed the cable and it came back on.
I ordered the cables and replaced all 8 (They did look a bit rough).
After putting all the cables back and putting it all back together ran a test print and the Black / Cyan heads are not printing. Had this issue before with my previous printer and ended up being a fuse. So i checked the fuses and sure enough one was blown. Luckily i had some of these, they are non soldered and fit into a little block soldered to the board, Replaced and tested, its the same, tested the fuse and was blown again. Changed again and tested again, no B/C still, checked the fuse and is OK, there are 2 head fuses and another next to them all 3 are good but no ink from B/C.
Changed the cables over and the B/C heads fire from the M/Y cables so the heads are OK..
Any ideas, could it be the Transistors?? There are two types A1746 & C4131..
This is where my limited knowledge ends, i dont know how to test them
Could there be anything else??
Thank you for taking the time to read this, and I hope someone will know how i can proceed.
Mark.
Mark.
