Roland VS 300-i No Ink From Head
Orlandoman
Roland VS-300i — No Ink From Print Head After Major Rebuild
Looking for input on this. I've been chasing a no-fire head issue and have replaced most of the signal path. Currently the printer powers up, heats, carriage moves, pumps cycle, everything appears to function correctly — but zero ink from the head on nozzle check.
What I've replaced (all new parts):
  • Print head (DX7) — installed, head rank code entered
  • All four head FFC cables (29-pin ribbons from carriage board to head — parts 1000006702 ×3 and 1000006703 ×1)
  • All three 36-pin BB High-V cables (main board to carriage board)
  • Encoder strip (carefully installed with gloves and IPA-cleaned groove, lint-free microfiber wipe)
  • Damper cover assembly
  • Drain tubing
  • F1 and F2 fuses on the servo board (3.15A)
  • SW Power Supply (LEB150F-0536-XRLD A, part 1000006130)
Background on the failures:
Original issue was the old head not firing — traced to a failed internal connection on the print head itself (the interface PCB had separated from the head body). One of the original 36-pin High-V cables also had visible damage on edge pins (pin 36 = VHV1, pin 1 = data line) so I replaced all three.
During the repair, I dropped a screw into the SW Power Supply and went after it with a magnetic screwdriver. Got an audible pop. After that, the printer dropped to "logic alive but nothing else works" state — 2-second shutdown, no motors, no pumps, only panel/LEDs/service mode accessible. Found visible arc mark on the PSU board near D102 with cloudy/discolored traces. F1/F2 fuses had blown protecting downstream circuits.
Replaced the PSU and the printer came back to life — pumps cycle, carriage homes, heaters reach temp, service mode fully functional, no error codes. Confirms PSU was the cause of post-screw symptoms.
Current state after full rebuild:
  • Printer functions normally in every way EXCEPT head firing
  • Heaters work and reach temp (firmware allows test prints, which requires heat-up)
  • Carriage moves correctly through full pass during test prints
  • Pumps run during cleanings
  • Service mode fully accessible, no error codes
  • Can pull ink through cap top with syringe — confirmed ink reaches the cap
  • Have run multiple POWERFUL cleaning cycles
  • Head rank code entered correctly from new head's paperwork
  • All FFCs verified in correct positions per section 3-21
  • Nozzle check: completely blank, zero ink
Suspect:
I think the head FFCs may have been weakened from being moved/reseated multiple times during diagnostics. New set of FFCs is being overnighted and will arrive tomorrow. Plan is to install them once and only once with no pre-fitting or testing.
Question for the forum:
Before I install the new FFCs tomorrow, is there anything else I should check or test? Anyone seen this exact "everything works except firing" scenario where new FFCs solved it? Any other failure modes I should consider given the screw-in-PSU event?
Printer is a Roland VS-300i, 13 years old, third head replacement over the life of the machine.
damonCA21
Have you tested the transistors on the mainboard? If one or more of these has blown when the fuses blew it can stop the head firing. It could also be when they blew it has damaged something else on the mainboard. The cables may fix it, as long as you get the correct ones and put them in the correct places. If not then you need to get the mainboard properly tested as everything else in the signal path should be good
Orlandoman
I tested the best I could , as of now I'm learning more twards a bad print head from Digiprint.
damonCA21
If you replace the fuses and disconnect the head completely and turn on, do the fuses still blow?. If they do then the problem is with the board not the head
Orlandoman
With the head FC cables unhooked , new fuses installed , power up both FC fuses still blow. Its this most likely the transistors ?
Orlandoman
Update ; Pulled all Transistors . 7 check close to 0.6 , one a 0.017 so one of them is bad . Can one blow fuses and cause a head not to fire ?
Orlandoman
It's it failry typical for these transistors to go bad ? I assume it went bad to ink leaking on the head ? or just old age 13 years old ?
damonCA21
It can be from age, but in that case they tend to drift in value. When you get a short or blown open it is normally from a short circuit. Ink leaking on the head can cause a short circuit that will blow the transistor., as can pulling out head cables when the board still has power in it
Orlandoman
Thank you for the reply , I just got done installing the 8 new transistors , now just waiting on the fuses to be delivered . I hope the printer will wake up today !
New Head , Dampers , FC cables , IC's all new flex cables , and PSU ..
damonCA21
Measure your transistors now they are installed and make sure you get the correct readings on all of them. Then you know nothing else in that part of the circuit has been damaged
  • Agree
Reactions: 1 user
Orlandoman
No I did not do that , But I can comfirm everything on the printer does work perfectly othrer than the ink firing ( last I tested yesturday) Just waiting for fuses now . I will see if I can get to them good enough right now to read them
Orlandoman
UP AND GOING ! TRANSISTORS FIXED IT !!!!!! If anyone has questions about this machine let me know lol , I think I know every circut now !
  • Agree
Reactions: 1 user
