The final chapter for now is the power supply has been removed and replaced again and that solved the problem. Even better, I had the tech reprogram the machine from the white ink option to a true 6 color, 8 cartridge system. The print head in there now had never had white ink in it and had only had cleaning fluid in it for those 2 channels.
And for now the VS-300, purchased in 2009 still rides along with our 4 head embroidery machine and our Merrow machine.
Parts replaced include the Main Board, the Power Board, the On/Off switch (which did test bad), the Plug Socket and Power Cord. We also had an issue with our ethernet connection. We run a mesh network with 14 pods and the ethernet port on the pod connected to the Versacamm would not hold the plug in. I just swapped it out and now we are Cut Low and Ready to Go!
Thank you all for your suggestions and for all of the help.
