Roland VS-640i / Yellow (Y) ink printing double despite new components
Valerio9090
I am experiencing the following issue with my printer:
Even after installing a new printhead, new flat ribbon cable, and new damper, the yellow (Y) color is printing double. This is clearly visible in the test prints (see attached images), especially with misaligned or duplicated lines in the yellow channel.
Additionally, during bias printing, one color appears to be missing or not firing correctly.
Important details:
  • The printhead is installed correctly
  • The head number matches the machine
  • The flat ribbon cable and damper have also been replaced
  • Other colors appear to print normally
  • The issue occurs consistently in both test prints and regular prints
Question:
What could be the cause of the yellow channel printing double or misaligned, even though all relevant components are new and correctly recognized?
damonCA21
Did you replace the long flat cable from the print carriage board to the mainboard? The error you have is that the head is not getting the correct signals when to turn on and off. This is either a connection somewhere between the head and mainboard, or a a fault on the mainboard itself
  • Agree
Reactions: 1 users
Valerio9090
Yes, you repaired the mainboard . Oddly enough, the first test print is okay after 7 hours, but the problems start getting worse with the second one. See the picture. I'll check the three long ribbon cables from the mainboard to the carriage board.
  • Agree
Reactions: 1 user
