Roland XC-540 2 heads not working
fastfreddy1980
Hello everyone ,
I just replaced all the heads on my Roland XC-540 ( heads , pumps , Cap Tops , FCC cables , Fuses ) and for some reason I cant seem to get the Magenta head and Yellow head to fire with ink , I also cant seem to get it to pull ink through the cap top either . Any thoughts on what may be the problem ?
damonCA21
If no ink is coming through the captop then you have an ink supply problem somewhere. Did you replace the dampers when you did the other parts? Check to see if they are full of ink. If they are check the manifold for cracks and the ink lines for any signs of air. Try pulling ink through the damper, if that flows fine then you have a blockage in the head.
