Roland XC-540 Serious Head problem?!? Never seen this before
servicemanager
I can't even find this problem listed anywhere on the web. We just typically use our printer for making stickers to put on resale vehicles.
Everything was working good last Friday but now we turned it on monday and this test print shot out.
Shutting everything off I can unplug the left bank of this head and the other half prints fine. So just half the head is firing whenever it wants apparently.
The odd part is the weird scratch lines happen on the first pass. It doesn't do it when it moves over and runs the second set.
Here is what I tried - multiple cleanings, cable swaps, damper swaps.
It's getting ink - it's just printing when it's not suppose to.
When you did the cable swap did the problem move or stay in the same channel? If it moved, you most likely have a bad cable or the main board is fried. If the issue stayed in the same place, your head is most likely dead.
servicemanager
Here is another copy
As you can see - if I turned the printer completely off and unplug the half side of the head - it prints fine with no problems with ink across the paper.
servicemanager
Well - we thought about doing that after we unplugged the cable and found the half head causing the problem. When we tried swapping the cables last night it popped the f2 fuse. We figured this had something to do with the ranking history and programming. Replaced the fuse and going to round 8 with this thing.
Just got done completely cleaning everything.
I am just wondering if half the head went screwy. The other half prints perfect!.
servicemanager
I will
give another check to the cable here in a few minutes.
Pretty straight forward i would think. I installed the new cable......plugged in and pulled back out several times to check wire marks.
servicemanager
checked cables
Nothing seems to be wrong with the cables.
HA - we just unhooked the cable that was causing the problem and did a test print with one of our logos.
Printed fine.......
If you can run it without a cable hooked up then we will probably just leave it that way for awhile.
We don't print any customer paying graphics. We just print different size logos from our company and stick them to trucks and trailers going out.
So just that color won't be as sharp i take it.
Most of our colors are black and yellow. Very little red.
MadStyle
Had this problem recently, It was Just a loose Magenta Printer ribbon cable, re-seated it and problem went away.
