Roland XG-640 Manually aligning crop marks
TVE0646
We recently replaced our Roland XR-640 with an XG-640. On the XR-640, if the crop marks wouldn’t read during a print, laminate and cut job, we could manually align them and proceed with cutting.
I haven’t been able to find that option on the XG-640. Does anyone know if it has the same capability and, if so, how to access it?
Thanks!
AB Rolan
Thanks!
When you setup your media to be cut, set the base point with your cut blade inside/over your cut mark circle.
Unfortunately, and ever since Roland came out with the printers with the panel on them, this option is no longer available to use the manual crop alignment “points”
