hi All,
Have SC500 converted from CJ500 machine. my problem now is when I print using Unidirectional setting, color drops out after few feet. But when I print Directional setting, print runs ok. I check and make sure the two clear line from the capping station are clear and it was. my questions now is:
-Is somebody have the same problem? if so whats your solution
-and on that clear two lines from capping station. Does ink or any liquid pass through that line or just completely air only. for right now i see spot ink flowing on that line.
Thanks for all the future help and advice
. Now I know where I made a mistake. Hopefully when clearing the 2 lines will also fix ink starvation after few inches of print in unidirectional mode. thanks again..
