Router Bit Suggestions
Think713
Hey everyone,
So we run an older colex router. I believe its an SX series... We use a er25 collet with a 6-5 shank diameter. The bits we get for routing aluminum and ACM are constantly chipping. Even for carbide bits I think this is a bit too frequent. All of the colex bits from their site seem to be single flutes, but we are looking at endmill bits for cleaner and more consistent cuts. Is this something we should try or do any of you have some solid suggestions for bits that will get through more than like 2 (4x8) before the bit starts fraying edges.
https://toolstoday.com/v-15030-48430-k.html. I found this bit here, and I think this might be a good option, but again looking for experienced suggestions.
We mostly cut: Acrylic, ACM, Poly Carb, PVC, Styrene, and Coro.
John Miller
Be sure you have your rpm and ipm settings correct, I've never had a single flute bit chip. Post what your settings are and the material thickness, type & number of passes. With that info people will be able to give you advice.
Reactions: 1 users
packratsigns
I've only used Belin Bits for over 25 years
The Amana brand is good but I have''nt used them.
13317 - 1/8 - for acrylic
33317 - 1/8" - for aluminum
33476 - 3/16" - aluminum
13476 - 3/16" - acrylic
33635 - 3/16" - aluminum
13635 - 3/16" - acrylic
Send me a private message if you want more info.
tulsagraphics
I'm "somewhat" new to real CNC work -- just got my first "big" CNC a few months ago, even though I've run Belins on a small Roland engraver for the past decade. ACM is soft. The only time I've had issues is when I ran cheap bits. Spend the extra $50 -- use a high quality Belin or Amana and you shouldn't have issues. Of course you need to get the IPM/RPM rates dialed in correctly. Expensive bits cost less than substrate damage or dealing with a bunch of unnecessary finishing work.
Think713
To be totally transparent, we just go with whatever defaults in the colex software for said material. Its never been a consideration, but it absolutely makes sense that it would.
Think713
Yea I wouldn't say we are using cheap bits cause we buy them direct from colex, but that doesn't mean they aren't. The general consensus between all of you has been Belin and Amana so, I think its a good direction.
nastewart0521
I'd highly suggest using these guys https://www.americanbitworks.com/ aka box canyon solutions.
They have a lot of options for the materials you are cutting as well as chipload info so you can dial in your cutting parameters. As always though, make sure to do a test cut when you are cutting any material.
JBurton
Signtologist
I use these, but I find the 33317A breaks less than the 33317 version. That being said, I've replaced a couple of collets after a bit broke right at the collet and it buggered the opening. I could probably offset the cost with less maintenance issues.
I like their 1/4 for thick acrylics, 13635. The aluminum version is far too loud for my liking though.
