Hi all,
We have:
Printer: HP R2000
CNC: Colex Sharpcut.
Flow: Print then cut.
Products: most are between 0.5 and 1 square feet, various shapes
Historically, we've produced only plastic products that are knife cut on the Colex, which is pretty much labor free. Customers would prefer metal over plastic for outdoor durability.
We'd love to be able to offer Maxmetal. The material cost is within budget. The additional time to route instead of knife-cut is tolerable. But our price points don't allow for labor on individual piece cleanup, or time to inspect for defects as a result of metal scratching the print surface.
My initial tests have revealed these issues:
- Routing will eat up spoil mats faster than we'd like, so I will likely opt for a separate CNC with spoil boards just for routing Maxmetal.
- I may not have the perfect bit for the job, or may need a better debris vac and/or dust boot, but we got metal shavings and plastic debris all over the prints.
- The polyester coating on the Digital Print maxmetal leaves some 'hanging chads' but they are easily wiped away (and I have not yet tried other bits or climb milling)
The metal shavings are the biggest concern - brushing them off scratched our print, even though the overcoat on our prints makes them fairly scratch resistant. I feel like the hot shavings are likely to affect the latex inks even if we blew them off instead of brushing them off.
I'd be willing to buy another high end CNC for this purpose if our goal of almost-perfectly clean products is attainable.
I asked AI for some recommendations and got:
ShopSabre - but it looks like the optical registration, production workflow is a bit clunky. Also seems we wouldn't be able to use it as a backup for the knife cuts on PVC foam (if Colex goes down).
Adding the knife cutting requirement produced:
1. AXYZ (Trident or Infinite series) — Best overall match for you
2. MultiCam (Celero or 1000/5000 series hybrids)
3. Zünd (G3 or S3 series with routing module) — Premium “cleanest output” choice
I'm hoping to find a machine that can achieve our goals that doesn't require a 9 month lead time, and ideally, isn't $200K (these are estimates from the AI on the Zund) -- but if it eliminates the labor I'd consider it.
Pipe dream or achievable?
We have:
Printer: HP R2000
