Royal Sovereign RSC-1650H Laminator all around help.
Jharris81
We have a RSC-1650H that is well used. We have had it for quite awhile and I have never really got the hang of it. I dont know what I am doing wrong. It kind of hit or miss whether it run well or not. When I run it it tends to start bunching up on the left side. When the print media comes over the infeed table you can see that it is not tight to the table and gets overly tight on the right side of the table. I have tried my best to load it straight. I usually load a starter strip that is 10 inches long or so to get it going. The with an inch sticking out before it gets to the roller I will stick in the media that is to be laminated in between the starter stip and the lower roll so it is "square" to the rollers when I start it. I have tried adjusting the pressure on the rollers and tension on the media, laminate. Just not sure where to go from here. It always starts out good but rarely ever stays that way. Any help would be appreciated.
Manuel Upton
We've had that same laminator for 20 years. It sounds like your pressure is not even across the rollers. If you search it on YouTube, there are videos on how to test and adjust it. Ours just this year got to the point where the adjustments aren't working anymore. I hope you have better luck. We are looking at the GFP 200 series for our next one.
