Rust Wrap
Darion Judd
I have like three clients that would be interested in wraps if i can just figure out how to design them! Any tips and tricks out there? I really like the washed look too.
OADesign
There is a software/plug in the lets to make custom filters that works well (enough) on large images. I've seen it done. I can't recall he name. For some reason I feel like Fred Weiss was well verse in its use. I may be wrong. Have you done a thorough search here?
Found it. Its called https://www.filterforge.com/
But premade textures are probably a better use of your time.
Darion Judd
Contact Scott at Skepple Inc. He designed the first two samples you posted. He is the rust wrap king. Have him design them and just install the wraps, save you a ton of time.
Good to know! I'll hit him up and see what we can do! Thanks!
I'll look into this! Thank you!
AKwrapguy
These are a lot of fun to design. While it doesn't seem like it at first glance there is a lot if detail in these wraps. For me, Photoshop would be the go to software for most of the design grunt work. I did one a few years ago, many layers and groups, but like I said the devils in the detail.
Fred Weiss
Here's a link to the rust seamless textures that we have available. They're available for immediate download in high resolution for less than $1.00 per image to subscribers.
westcoast local
alienskin eyecandy might help also they have a rust effect and blow up software if that helps at all...
