I just took delivery of the Summa T160 OPOS Cam last week.  Im running into an issue with Flexcuts specifically on inside corner cuts.  It is overcutting and leaving like an X cut on every inside corner.  I have dialed in everything as far as pressure for the knife and flex pressures.  The decals pop out with a little flick so I believe I have the pressures set correctly.
Overcut was set to 1 so I changed it to 0 with no real change. Ive tried decreasing speeds and still the same issue. Kisscuts do not have this issue. It cuts perfect.
Im using Flexi but have all settings turned off so that it uses the cutter settings. Just to eliminate Flexi out of the equation, I sent the cut file through Winplot and exact same issue.
Anyone else have this issue? Any suggestions on what I should try?
Here are some really zoomed in pics:
https://imgur.com/a/aQj7Wtb
