S40600 damper
SameDay Signs
So I’ve been getting ink starvation nozzle cighecks good and of gone once do clean they come back perfect and sometimes a lot are gone then perfect and once I whole whole prints good sometimes not
So my question is where in ohio can I get tech to replace damper unless it’s pump but I’m not guessing it’s that? I was quoted around 600 which I was fine with but upon actual quote was over $1100 so I’m searching to see if anyone has ideas suggestions or places to contact - at a certain point I’d buy another machine before I drop 4k or something into ti
funnyb0nz
Did you get this fixed? I have a 40600, had same issue. Was printer head. I replaced pump cap assembly, first hopeing that I would of gotten lucky. I am in NW ohio, I have the software to get into these machines to do the work properly per Epson.
funnyb0nz
Also what you could do is if its only happening in one color, take out the damper, clean both sides out and flip it. You should see the problem go away from one color but have issues with the other color. You can buy these new for $30.00 Typically its only one bad one and no need for a $300 and something assembly.
jfiscus
Rap Master
Trigon Imaging is in Ohio and is actually a licensed Epson Service company. There aren't many besides D1 out there, so at least you do have a couple options. I do NOT recommend D1 for service.
SameDay Signs
I actually went to Trigon to get it worked on and they did a good job it was the damper. Way better then the head
