SDS Trimless Channel Letter Questions
Axle
We recently got the new SDS channel letter bender. The machine is working very well. Especially on our everyday regular trim cap letters. One of my reasons for getting this equipment was to be able to produce trimless letters. The SDS material system is well thought out but the company is totally lacking in the educational side of how to correctly and easily use these items to make trimless letters. We have pretty much figured it out and just finished a very nice set of letters. One of the biggest issues I have had is finding the correct screw to use with their stainless clips that hold the returns to the backers. Because the clips are stainless screws have a hard time threading into the clips. The idea of how these clips work makes sense but it is flawed. So the reason I started this thread was to se3 if anyone else has had experience with this and would be willing to share any tips or input.
DarkerKat
design & such
Not a helpful reply but yes, their educational resources suck. I like the machine but working with the company has been a headache. The guys that came to train us couldn't understand why I (the design director, who trains all the other designers on how to setup files for production) even needed to be there. And when we asked for a manual we were told "We just build the ovens, we don't teach how to make pizzas". On the clips - love the idea, seems really handy, but they only work if your letters are already perfectly bent. Our guys in manufacturing refuse to use the clips now because they don't catch screw-threads well enough to hold the letters together- we tend to use little acrylic blocks in their place.
Hopefully someone else can provide more useful direction.
Axle
Thanks so much for replying. At least I know now it is not just me. We too have discussed using acrylic blocks in place of the clips. I would assume you just glue the blocks on the backer panel right under the rail the backer sits on? Do you still use the ca glue on the acrylic blocks?
DarkerKat
design & such
Annoyingly, I don't seem to have good pictures of the inside construction of our letters, so hopefully I can explain this well enough:
- For standard front lit letters - The acrylic Faces are attached to the coil via CA Glue / Acrylic Glue + Clear silicone on the inside. Backers (we've primarily been using ACM for these) are mounted to acrylic blocks via lords adhesive, then the trim/backer rail on the inside of the letters is manually cut out in those areas so we can slot in the backers and screw through the sides of the letters to hold the backer in place.
- For back-lit letters we have been using ACM for the face cut so that it can sit flush with the front of the channel, attached to the coil with Lords + bondo'd to kingdom come to get a smooth finish without light leaking through, then sanded and painted. Acrylic backers get clear acrylic blocks mounted with Acrylic glue (to fuse the backers and blocks together), then the trim/backer rail on the inside of the letters is manually cut out in those areas so we can slot in the backers and screw through the sides of the letters to hold the backer in place.
** I know this is not the best method, and it's painstaking for the guys to have to cut those stupid rails off where the acrylic blocks are but then they can sit flush with the coil** In theory we could just cut the acrylic blocks with an indent to avoid hitting those rails in the letters and skip the manual removal but our CNC operator cut a bunch of acrylic blocks, forgot to put the step in and wanted to use those up before we tried anything else
We are still working out the kinks and experimenting with other methods but until very recently the SDS machine was in our new building across town while our team still worked out the older building (we just finally moved everything over the holidays) So any testing/troubleshooting for the past year has been a headache and a half.
Axle
Really appreciate your input. We put this first set of letters up today and I have to say I really like the look. We are going to try the acrylic blocks the next time and I will post how it works.
  • Agree
Reactions: 1 users
Chemcon-John
Following this thread because trimless letters keep coming up in conversations we’re having with sign shops.
For context, we supply adhesives and work closely with manufacturers when they’re trying to make trimless builds more reliable. We don’t fabricate the letters ourselves, but we’re usually involved when a process starts feeling risky or inconsistent.
A lot of what’s been said here lines up with what we see:
  • CA/superglue is still the default because it’s fast and familiar.
  • The stainless clips make sense in theory, but once bends aren’t perfect, many shops lose confidence and move to blocks or other internal fixes. Or they may not want to see the screws.
  • Those workarounds aren’t pretty, but they feel safer, especially on larger or exterior trimless letters.
One thing we’ve had some good early success with is UV-cured bonding on trimless returns. Not replacing CA everywhere, but used where straight CA starts to feel brittle or sketchy. The big benefits so far have been instant cure on demand, cleaner joints, and less stress during assembly when the bond area is really thin. Still early and we’re validating it shop by shop, but it’s been promising enough that a few larger shops have kept it in their process.
Curious how others are handling this:
At what point does CA alone stop feeling comfortable for trimless letters?
Are you adding more mechanical support, changing bonding methods, or just accepting the extra labor?
Always interested in comparing notes.
