Second surface or sub surface prints behind clear acrylic
packratsigns
Hello,
Looking for guidance on Second surface or sub surface prints behind clear acrylic .
Materials , technique ?
Is there a laminate with optically clear adhesive ?
we run a Roland VG3-640
Thanks All !
TEN
Are you printing and applying clear vinyl 2nd surface? Are you printing with white ink? Depending on the actual application I don't think you need to laminate the print, such as if it is a logo applied second surface to an acrylic panel that is mounted on standoffs.
MarkSnelling
Mark Snelling - Hasco Graphics
Will the entire sheet be white or are you going to have clear areas? That will dictate what you use.
If it will be all white behind the image, then you can print on any white film or high end paper and use an optically clear adhesive to mount the image to the acrylic. I've got a great optically clear adhesive.
If you are going to have areas where you want it to be clear, then you'd have to print on an optically clear film and use that same adhesive. You could also print on an optically clear laminate and stick that to the acrylic.
You are more than welcome to call me to talk it through, but this is a fairly standard practice.
