Seiko 508gs Or 510 35pl
cybernalin
i need to buy a new machine and what should i buy
is there any experience user here 508gs or 510 35pl
what i need is less clogging heads
currently using 255 35PL heads and it's really hard to maintain
bilge
510 35PL is basically the same as 255 35PL only twice wider i.e 7 cm. If you talking about chinese printers, use SK4 ink clogging should not occur. You need to check voltage and temperature settings of the heads constantly. Keep your room below 20C degree. If you are going to buy from China, just contact FeiYeung Union to ask which model is suitable for you. It is the sole distributor of Seiko printhead and the best OEM you can find over there. I've heard KM heads are better than Seiko, but I don't know which printer works.
