You can setup a shortcut to the input folder... Then when you go to save your copy (eps, pdf, tiff, whatever) you select that shortcut and the saved file goes directly into VW so it's there waiting for you. I believe some RIP's refer to these as "Hot Folders"
I use a Mac so I've got a little shortcut on the left of my Finder window that says Input A and Input B (one for each print queue in VW). So if I'm in Illustrator or Photoshop I select "Save a Copy", then click my shortcut for the input folder, give it a name and click save.
**Be sure to save a COPY in those input folders, you still need to save the original file wherever you save your other client files. The files "disappear" once they're processed, so if you don't save the original somewhere else you'll have to go through a few steps to try and retrieve your original artwork file. I posted instructions on how to retrieve files a few weeks back if you ever need to do that**
Then when I go over to the RIP computer (usually control it remotely via RDC) my files are already imported and waiting to be ripped. I don't have to waste time navigating folders looking for the file I want to print.
The input folders are located here:
VersaWorks Program Root>Input-A
VersaWorks Program Root>Input-B
Your VW Program Root is typically located at C:\Program Files (x86)\VersaWorks
