Serial to USB for GSX plus
Just bought a new computer and it doesn’t have a serial port for my GSX plus plotter. I assumed Gerber would be reasonable and allow me to use a simple adapter, but no. It’s a freakin $100 branded adapter from them or the plotter doesn’t run. Has anyone found any sort of work around for this? I’m actually considering trying to figure out how to transfer my serial port from old computer to new one.
Joe House
Sign Equipment Technician
You can use a generic serial port to USB adapter for the plotter, but you should get the Gerber one if you're connecting an Edge. Just make sure that the serial port can be configured through it's driver. It's much easier than an internal card. I've used this Keyspan adapter for years.
Good Luck
Thanks for the info. I’m actually using a network cable to connect my Edge and it works fantastic. It’s the plotter that doesn’t work. I’ve got a generic adapter now and the computer isn’t recognizing the plotter, even when I select the specific port it’s plugged into.
timgo
Graphics Designer
What is your Windows version in your new PC?
The drivers of your old software are not compatible for your new PC with new Windows.
FunkotronXL
Not all of the adapters are the same, we all wish it wasn't the case but these are the penalties of older equipment. Try the adapter Joe House linked higher up in the thread. That will be the most inexpensive option.
That Keyspan will work with Omega to the GSX plus? I tried loading the drivers from the Omega disc to the one I have (by Prolific) and windows said it has a better driver and wouldn’t use it.
What drivers would I use with the Keyspan one? Since the only drivers available online are for Windows 7?
