Set up in Versaworks for nesting multiple prints
DAHVID
I have a bunch of small sign designs that I'd like to group within multipl 18x24" areas to be printed on vinyl, applied to corrugated plastic and then manually cut out from there. Is it possible to drag all of the files (55+) into one nest and then tile the groups of graphics to stay within the above dimensions to print multiple at once? Or do I manually set up artboards in illustrator to these dimensions? Just trying to figure out the streamlined work flow for this idea. Printing on Roland SG300. Thanks.
Depending on what version of Versa Works you are using, in VW6, you just click on the files and you can use any Windows method that you know like holding down the control key. You can select all these and make a “nest” job. There is an icon at the bottom of the screen to nest the job once you have them selected.This is not considered “multiple job grouping”, that is something different. Of course you do have all this information and the Help feature of Versa works. As well as on the DGA VW training videos.
even within nest job on the layout screen, you can move around the way you want.
  • Agree
Reactions: 1 user
