Can you elaborate a bit?  As in putting a wax finish over the floor graphic?  If that's the case, I've seen that done so the entire floor has the same surface, but I never understood why people did that because when the graphic is removed there is a spot which needs to be waxed again.   I'd also be afraid of the legal implications of not having a UL rated non-slip surface.
