Sieko Colorpaint 64
salsvg
Can you Do a test print with the Sieko Coloropaint 64
without the computer hooked up want to test to see if the heads
are shooting properly
d fleming
Offline- cancel shift cancel cancel, password prompt is shift up down right, then left to h.adj, hit enter three times to execute nozzle test pattern
boxerbay
from and ex-seiko 64s owner - old machine don't buy it. you will forever be fighting banding, drips, sucks up a lot of ink to clean the heads.
mindgames.1
Seiko colorpainter 64s (IP6600) Hot question about PC operational system
YES! Many thanks, it works!
Enyone knows something about the compatibillity between Seiko (IP 6600) and Windows 7 (64)... Someone who has this kind of structure...?
Many thanks!
N.B. PC system Windows 7 (64 bits); 4GB RAM; SCSI port; Wasatch SoftRip v. 6.7
danno
Negative Ghost Rider, the pattern is full.
Check with your RIP manufacture. Onyx has a driver that will work with windows 7 for the HP9000. Not sure about the colorpainter. I would think it would be harder to aquire the SCSI card.
mindgames.1
Many thanks, Danno! I will check (with Wasatch SoftPrint v6.7 driver suittable for ColorPainter 64S using SCSI and Windows XP, exist).
Right now I will check with a demo version of Scanvec Flexi Sign - Photoprint DX 11.
have to install and check the right now!
