Sign Pricing Methods
ChiknNutz
I’d like to get some feedback on this issue of pricing. This is a fairly long post, but I really think that you’ll find it both interesting and thought provoking. I think it may also challenge some of us to take a look at how we go about our pricing.
Typically, the questions that get asked are, “So what you would you charge for XYZ, using ABC this and that?” Well, I want to move beyond that and be a bit more generic in the type of sign, and focus on the how do you get there. In recent weeks I’ve posted a couple surveys with the hope of gleaning some useful information on how long folks take to perform some common tasks and couple that with what you’d charge for that common item. Though I’d hoped to obtain more responses than I have so far, I think the trend is good enough to draw some basic conclusions. I won’t reiterate the entire contents of the survey here; I’ll show the average of the data here for the point of discussion. Here is the link to the survey for a refresher if necessary: http://www.surveymonkey.com/s.aspx?sm=7Uz2fT0E4YNEZhdN3kaeBg_3d_3d
For the purpose of this discussion, I want to try and keep it simple and not get into all the “What Ifs” okay? What this is about is an average amount of time it takes to do an average task by an average worker and NO design time is included…just the sign. If you’ve been at it long enough, you have a feel for what an average job is in YOUR shop. This actually may vary quite a bit from shop to shop, based on the type of average work you do, so that variable can’t quite be integrated here, but let’s hope we can still get on the same page for this.
It seems that many experienced folks propose that you determine your Shop Rate, based on all of your overhead, apply that to the job, and then add for materials with a markup. What the data shows actually seems to contradict that in my opinion!
Using the data obtained for an average computer-cut vinyl sign that is a standard 4’ x 8’ aluminum composite or similar, here’s what YOU said (again, on average and I’ve rounded the numbers for simplicity). Incidentally, the average response shows 10 years of experience:
  • Time it takes to computer cut, weed and mask 32 SF of 1 color of vinyl: 40 minutes
  • Time it takes to mount the masked vinyl to a standard substrate: 22 minutes
  • Average retail price for this sign: $430
Using the data obtained for an average digitally printed sign that is a standard 4’ x 8’ aluminum composite or similar, here’s what YOU said (again, on average and I’ve rounded the numbers for simplicity):
  • Time it takes to RIP a file for 32 SF of material using your typical settings: 17 minutes
  • Time it takes to laminate the print (4' x 8' or equivalent): 14 minutes
  • Time it takes to mount the print (4' x 8' or equivalent) to a standard substrate: 16 minutes
  • Average retail price for this sign: $454
Let’s focus on the cut-vinyl sign first. What I find interesting is this. Though I did not ask for your Shop Rate (now I wish I would have), I find that there is more going on here than just a Shop Rate plus materials and markup. For the sake of discussion, let’s assume you Shop Rate is $75 per hour. For this job, then, if it takes an average of 62 minutes to produce the work, then you should charge $77.50 for your production time ($75 * 62 minutes / 60 minutes per hour). Let’s then assume that you use Dibond and it is $95 per sheet and we’ll also assume that you double your costs….that comes out to $190 with 2X markup. Let’s also assume that vinyl is $1.00 PSF and transfer tape is $.10 PSF, so that yields $35.20 at cost and $70.40 with 2X markup. So, the grand total using strictly a “Time and Materials” concept is: $337.90 ($77.50 + $190 + $70.40) which is $10.56 PSF
However, the average selling price is coming in at $430 ($14.19 PSF)…which is 27% higher. So where is the difference then? If you are truly using a Time and Materials model, where are you coming up with this additional 27%? The way I calculate it, you’d need to have a Shop Rate of $184 per hour, which I doubt anybody is charging yet. Either that or the estimated production times have been grossly underestimated.
The same goes for the digitally printed sign using the following numbers and assuming the same $75 Shop Rate:
  • RIP charge: $21.25 ($75 * 17 / 60)
  • Lamination charge: $17.50 ($75 * 14 / 60)
  • Mounting charge: $20.00 ($75 * 16 / 60)
  • Assume your printer takes 30 minutes to print 32 SF, so using the same formula, that would be an additional $37.50
  • Total production time charges: $96.25
  • Substrate cost of $95 yields $190 with 2x markup
  • Assume Oracal 3551 vinyl ($.40 psf), 210 laminate ($.36 psf) and OEM ink is $.34 psf. Total printing costs are $35.20 and then $70.40 with 2x markup
  • So, total time and materials charge to client is: $355.60 ($11.11 psf)
As before, the average selling price of $454 ($14.19 psf) is 28% higher than when pricing it out using just time and materials.
What’s interesting about this, both production methods show almost the exact same percentage of ‘overage’? So, where is this additional amount coming from? Is it based on the perceived “Market Value” or is it something else? I contend that most people do in fact use a Per Square Foot charge for the most part, or they are adding on an additional fee beyond their time and materials. I look forward to the comments. Thanks if you've come this far!
ChiknNutz
Alrighty then. This post isn't THAT long! Not a single comment of any kind. So either no one has an attention span bigger than a flea or this is all just useless information. Seeing as how EVERYONE has to price their end-product, I thought this might be helpful. So which is it...really?
wildside
your numbers are interesting, and yes i did take the survey. IN our pricing method using cyrious software, everything is covered as long as all the formulas and input is correct
for instance on this 4X8 sign with the digital print, the system will tell me what the cost of my materials are going to be with time of production included based on the times pre entered into cyrious
it tells me the percentage it will cost me to produce and the final selling price, and allow me to add modifiers to up the price more
as far as the 28% higher, i would assume some misunderstood the concept and included design time, or was ball parking for a hope to get price not a realistic price, or just plain and simple the 28% is the profit margin exposed to some degree
my system warns me if all the costs involved make up 25% of the selling price with a caution, and the "big red box" if i am within 40% of the selling price....this helps me control everything, the only time i get into trouble with pricing seems to be when i shoot from the hip onsite without truely thinking it through....
Checkers
Net profit perhaps?
Besides mark ups and/or margins, a business needs to be profitable. A 20%-30% net profit is good to keep your company healthy.
Checkers
Fred Weiss
I think the reasons for the difference are several which you pretty much covered.
First off, we included design time in our pricing which was our understanding of your survey question. We would only adjust the design portion of our pricing if we felt that excessive design time was going to be the case or if we were producing a quantity of the same sign.
Secondly, we are not only local market oriented in our pricing but also internally oriented in that we have determined the minimum we are willing to do any particular sign for which is a combination of what the market is and a recognition that Murphy is alive and well and living in Lake Worth, FL.
Time and materials is something we use as a secondary check on our square foot pricing and which we periodically adjust to match current costs. We take most work as generic and apply a predetermined current square foot rate with adjustments for smaller sizes, quantity and non-generic items which would effect the cost.
We don't take perceived value into account because we are talking about produced work and not design as a rule. Produced work is directly effected by competitive markets because the only difference is how well one produces the work. Design is much more subject to perceived value because it can be so radically different from one provider to the next and because the benefits of good design are more far reaching. We are typically higher than our local market for sign production and have focused on relationship building with our clients instead. This allows us to normally charge what we are satisfied in receiving for sign production without regard to competitive market conditions.
ChiknNutz
Net profit perhaps?
Checkers
Absolutely, but your Shop Rate should account for profit...whatever you want that to be. So, using a Shop Rate of $75/hr should already have that factored in. Unfortunately, I failed to ask for everyone's Shop Rate to see if that correlation was true. On a personal note, I recently re-evaluated my costs and found out that I needed to charge approx. $80/hr to reach my goals...which only included a 10% net profit!
Based on the numbers shown here, we also do not include the fact that we are obtaining income from our materials markup. That is above and beyond the net profit built into a Shop Rate. So we're still seeing an add'l 28% on top of that. While I'm in no way saying that we should all charge LESS...but I do find it interesting that on average, we are getting this add'l profit and just wonder how it is factored in.
ChiknNutz
First off, we included design time in our pricing which was our understanding of your survey question. We would only adjust the design portion of our pricing if we felt that excessive design time was going to be the case or if we were producing a quantity of the same sign...
Actually I specifically indicated to NOT include any design time...to only price this according to production.
5. Assuming artwork to be of average complexity, the sign is created by someone of average skill and the workflow is of average time...what would you charge the average client for this 1-sided 4' x 8' sign? Assume the vinyl is high-performance and the material is aluminum composite. Do not include any artwork time or other fees.
Fred Weiss
I charge 100% markup on materials which I consider to result in either a wash or the creator of a negligible profit by the time I toss out scraps of substrates or wasted print or cut vinyl mistakes and malfunctions.
What isn't part of any calculation here is the balance between the optimum prices for one's market as compared to the more cut and dried this is what I need to get approach. I have long and often recommended closing rate tracking as part of price setting. It's the only way to make rational decisions about pricing.
If I find that, in your example, I get the job 95% of the time at $10.00 a foot, 75% of the time at $13.00 a foot but that I only get the job 50% of the time at $14.00 a foot, then I am armed with information I may want to take into account because sales time is a cost of doing business also. In other words, there is an optimum price to quote at which takes into account the cost of the time lost in failed sales time invested.
If I spend 40 hours a month in selling and preparing quotes and I value my time at $75 an hour then I have a cost of $3000 a month. At $10 a foot, my lost sales time amounts to $150 a month. At $13 a foot, I'm up to $750 a month. And at $14 a foot, the lost time amounts to $1500.
This lost time expense can then be applied against actual volume of work done to arrive at an optimum price point for your business in your market.
Hope this makes sense.
Chris,
I think some of what you are seeing in the survey can be partly attributed to any of the following three things.
1. Many people will quote job times based on what they feel the process entails. What often gets excluded is the prep time, which does include getting everything ready for setup. All of this adds up and should be charged.
2. In many surveys, the pride factor comes into play and you will see a natural "I can do in xxxx (time).
3. Final charges for a product actually being based on what an "average" person would need for proper production.
I would like to believe that the third reason is the most common (as it is what I do). You see, the way I view pricing is that my skill level gained via experience is a bonus to me and irrelevant to the "customary hourly charge". The flip-side is that there are limits for what new and inexperienced people can charge. Also, reason 3 does equate to the $200/hr as you stated, without actually stating that as a labor charge (which could have an adverse effect on business).
Fred brings up some very good points also. To be somewhat off-topic and survey aside, his points are often neglected in the calculations of profits and costs - especially to newcomers.
Checkers
Hey Chris,
Just for kicks and giggles, I double checked your numbers. While they're accurate to what you're demonstrating, your material costs may be a little (or a lot) different than what others are estimating or paying. Just for an example, a sheet 4' x 8' sheet of white dibond can vary as much as $44, depending on the thickness of material.
Shipping costs can make a difference too. A recent order of vinyl from a new (to me) supplier added an extra $10+ in shipping costs to the order. Whether I pay for it or not, I generally figure an additional 10% - 15% on my material cost to cover shipping. While it may not sound like much, it can add an additional $20 or more to the total cost of the sign.
Anyway, @ $75 an hour, the bottom line for a "time and materials" price, assuming 4mm dibond, would be about $410. A more realistic quote from me, accounting for the variables of running a business, would be closer to $475.
Using my estimating software, which also accounts for personal taxes I pay the government (28%) and the net profit (20%) on the sale, my retail price would be $519.
Checkers
Checkers
BobM
I try to figure me costs on each job and come up with a price. Quite often I look at the price and make a determination that the market will bear a little more or if business is especially slow and the customer shows future promise, I may offer a "one time special discount".
Bottom line is it is difficult to anticipate and remember all your costs, especially when you're a very small shop and are bouncing around all the different types of sign work.
I read every post regarding pricing on Signs 101 and see "accounting 101" theory everywhere. 1 to 3 person shops have to react from the gut to keep up with the sales, production, installation and customer relations to a point where time doesn't always permit detailed job costing. Often times I finish a job and drive away saying I didn't charge enough for that work. Sure enough when I take the time to actually review each job completed, hindsight becomes 20 - 20. Leaving only $25 on the table a few times a week adds up to several thousand dollars a year.
That's why your software is particularly interesting. It comes loaded with "average" material costs and fill in the blank questions that lead to reasonably accurate and consistent pricing. It's one thing to knowinly allow a discount, a totally other thing to leave out or undervaue your work.
Looking forward to the new version.
