Oi Vey, Good question . . .
If you haven't already, you should invest in a
sign estimating book,
software or a combination of the two. That's not a reprimand, just a friendly suggestion, you will thank yourself in the long run because it will eventually save you time as you begin to produce more
signs.
As you know, the cost of the material in most cases is a minor component of pricing your
signs, most of the cost involved is in the time associated with layout/design and actual construction.
Estimate has an hourly rate calculator and a project timer you can download for free from their website
HERE I would recommend starting there to find out what YOUR hourly rate should be, obviously, your rate won't be the same as the powerhouse
sign companies but not as low as eBay sticker salesmen.
Once you have figured a rate that is not only fair to the customer but also fair to you, you will be on your way to a profitable, successful little business. Currently I operate solely as a designer and my pricing is aligned with some of the other designers in my area, a little higher than a few but lower than most. By being fairly priced, I am able to purchase software updates, font collections and clipart as needed. The money doesn't need to come from personal funds anymore.:Big Laugh
As far as pricing the material, charge them for the entire sheet of material, you don't have the other job "Locked and Loaded" yet, don't take the chance on sitting on material you won't use.
Knowing a little more about the project would help too: How many lines of text and how high are they? Are there any graphics involved and will they need to be cleaned up? Are you ordering any other materials specific to this job?
Material cost $400 - $600 USD
Time $200 - $400 USD
Customer pain in the behind factor $0 - $400 USD
Total $600 - $1400 USD
Best of luck to you!
