Kind of similar problem as last post. First time I'm trying to do a print&cut.
a)designed in SignLab and added registration marks (inverted Ls) on 4 corners and contour cut lines
b)printed with Mimaki JV3 and laminated, printer is in another room so the printer is not loaded in my SignLab
c)carefully cut sheet leaving enough space on edges and loaded with the rollers outside the registration marks, the plotter comes with ARMS.
 After this I'm kind of lost, I tried doing jogging, but it seems like that has to be done manually, defeating the automatic part.
Any tips I will greatly appreciate, pls pm if you want me to call you.
Thanks for looking!
akuarela
After this I'm kind of lost, I tried doing jogging, but it seems like that has to be done manually, defeating the automatic part.Any tips I will greatly appreciate, pls pm if you want me to call you.
Thanks for looking!
akuarela
