Suggestions Signs from solid materials such as laser cut acrylic sheet
Diverse Laser
For bigger signs we can cut sign artwork from sheet, such as acrylic or wood, and these pieces are attached to the sign structure. Many different colors of material can be used for visual effect. And two-layer artwork can also be used to give the sign the appearance of depth.
Laser engraving can also be used in certain cases to make the artwork, using wood as one example of a chosen material for engraving. Although this is usually for smaller signs due to the extra expense of engraving. See our website photos showing a wooden label. as a example. Doing it this way provides a 3-D effect to the artwork of the sign and can be stronger structurally.
We can make the resulting one-piece artwork at up to 3ft x 4ft size. as a minimum.
