SellersSign&Design
Has anyone tried the Siser ColorPrint Soft Opaque with a HP Latex printer? It doesn't say it is compatible on Siser's website, but it sounds like good material so I'd like to give it a try.
			Ok Shucks... I was hoping you had onyx, I think I still have all my old l25 profiles.
I always used the HP low temp preset and we built a profile based on one from HP and Chemica.
I know our heat settings were at 180 for the cure and 130 for the dryer. I can't recall our airflow settings though.
Also are you having issues with other materials not drying right at normal temps? It may be the signs of the heater core going out.
That is the signs of the heater core going out. The left side doesnt dry well on saturated colors then you'll get the temperature error codes.
Honestly I think you are having the issues with this material due to the heater core and not the material itself. When the heater core starts to go temps get erratic.and then slowly fall off until it triggers a out of range error.
