Small Letters HELP! Graphtec CE3000
binkdesigns
I'm having problems with very small letters coming up on my Graphtec CD3000. I switched to a 60 blade to see if that would help.. It was okay at first but went back to pulling letters up again and getting sloppy cuts.
Here is my current setting cutting out oracle 651
TOOL 09U
OFFSET -1
FORCE 14
SPEED 10
QUALITY 1
Please let me know if there are any suggestions! I need to get these done..
TresL
How big are the letters?
I use a 45 deg cutting 651 with no issues on my CE3000.
I do run more offset, but each cutter will be a little different there.
binkdesigns
Everything is clean in the blade.. Tried lowering the force to 13 but wasn't enough to cut out the test triangle
binkdesigns
Thanks for the help.. I Ended up finding my problem though going through the file.. I had copied another layer on top and didn't realize it was there..
