soljet pro iii
mwalldesigns
Hi here,
just purchased this machine and having a issue with cut function. Carriage goes through the motions but blade doesn't move. Any thoughts would be appreciated.
XL_poster
print it easy...:)
media cutting off problem (just horizontal cut): the the carrige at the end point, is not close enough to turn on the cutting mechanism. solution > lover the gap with sticked paper, plastic or so, as needed.
if plotting problem: Stuck blade? wrong ballbearing in the blade adaptor. Is it possible to manually move the blade?
niksagkram
I'm not a technician, but you may have to perform a "limit position and cut down position initialize". I've had this happen to me before, but I was getting error codes too. I have a paper copy of the procedure, not an electronic copy, but if you do a Google search you should find a .pdf
Take a look at this video too.
[video=youtube;eN16a9pPp58]https://www.youtube.com/watch?v=eN16a9pPp58[/video]
Good luck,
Mark
