Click to Support Signs101 ...
When I don't print often at times the M will draw up into the Y line and I need to do a few head cleanings to get the Y back. Anyone else have it happen or know why?
Bad damper and/or captop. Change both and it should fix it. If the captop isnt draining properly, or the damper is letting ink drip out, the ink sits in it, then overnight can seep back into the damper and ink line. Both colours actually mix, but the magenta is darker so you notice it more in the yellow ink line.
I had an old SP that would do this. Perfect advice above, but in the mean time, print a block of yellow until the magenta clears out right before sending your print you are trying to print. It will clear the Magenta faster and easier than cleanings and/or test prints.
