Hello Everybody,
I am using Roland Versacamm SP-300V for maybe 3 years. I have manually removed the heads for cleaning already two or three times, but when I did it yesterday the printer didn’t want to print. Here is what I did and what happened:
After I switched off the power removed both heads, cleaned them with solvent cleaner and then put them back. After this I made cap alignment, thermistor check and when I went to head alignment I saw that the black/cyan head is not printing. Tried to pump up ink and head cleanings - there was ink in the head, but it was not printing. Changed the flexible cables between the two heads, but there was no difference. Then I changed the cables that are coming from the board and put the flexible cables that were going in the magenta/yellow head into cyan/black and it was printing only black now. That should mean that the head is OK. Then I removed the board to have a closer look, I supposed that the problem is in it, but saw nothing wrong and put it back. And after this my Roland does not print at all – the yellow/magenta head also stopped.
I called the techs, but they told me that have to see the printer first, now they have a lot of work, and can come to my town next month.
If you have any idea where the problem may be I will be very grateful.
Thank you in advance, if necessary my email is nikelson@abv.bg
