SP-300 Service Call 0121
dusigns
Hi all...
We just purchased a used SP300, on initial power up (after moving), it's giving me the error "Service Call 0121"
It's late and Roland Tech Support are closed, so thought I'd give this a try -- any ideas?
It was fine before we moved it from the previous owner's shop, so I can't imagine it's anything too bad.... Does anyone have a service manual for this beast? I can't seem to locate one online.
Jason
humpsigns
roland sp300v 0121 service call
having the same problem 0121. where are the thermistor located on sp300 printer
humpsigns
humpsigns
yes.. I owned the roland sp300v for four & half years only had to up grade pump..now encoder strip....took front cover off to clean dust then it came up with service call 0121...thinking it might b encoder strip no reading right..getting one friday..but want to get head start on finding the thermistor on printer..have the service manual, but can't seem to find them.ominiscience said there were two of them.. also have service manual on mimaki jv3-160sp if anyone is in need of one.
CS-SignSupply
The thermistor is a cable that connects to the inside of the front bed cover. If you took the cover off, you may have damaged the cable or it may have come unplugged.
humpsigns
I have the cover back on know..would it b the small black one that screws into the cover like a ground or one of the white ones?
Thank You,
Humphrey Signs
humpsigns
You don't think the encoder strip would have any thing to do with service call 0121.
Thank You,
Humphrey Signs
