SP-540 How to find IP Address Using Roland InterCon-NetTool
Steve Brown
Hi,
I have checked all the menus and cannot find where to set the IP Address for my SP-540.
I have also run the Roland InterCon-NetTool to see if it would pick it up but nothing.
Is there a way to find what the IP Address is set to on my SP-540.
Thanks.
Ragnabrok
if it's an sp-540i, it's system info->network->ip address, subnet mask, gateway
if it's an sp-540, or sp-540V, then it's net-tool. if it isn't showing up in net-tool almost immedialty after hitting the refresh and rebuild buttons, you can reset the network card on the printer by turning off the main power switch, holding the smal blue button the the network connection, powering it on, waiting ten seconds, repeat that process and fire it up normally. try net-tool again.
Steve Brown
Default IP Given to Roland when Reset
Hi,
Thanks for your reply :)
The Print & Cut is an SP-540V so I do need the net-tool. Can you tell me what the default IP address is after doing the reset of the network card?
I think I may need to set me Laptop to this range when using the net-tool.
Thanks.
FrankW
The Intercon-Nettool will find devices too if they don't have a default IP in the same range. If your printer don't appear, you should check your network connection.
