Goatshaver
I initiate the job in versaworks to cut only, submit it to start the cutting, it goes to processing on the machine for a few seconds but the cut head never even moves and then it stops processing like it's finished. Not really sure whats going on. I can do test cuts fine but this file isn't cutting and it's the same file I used previously, cuts are showing up like they should.
I had a test cut file I tried for when I set the knife pressure and that worked fine.
