SP-540v won't cut
DAHVID
I picked up a roland sp-540v for the highschool graphic design program i teach at. We have a roland sg300 and needed a larger format. I went the budget route and was able to pick up the roland sp-540v. I cannot, for the life of me, get it to cut CutContour paths. I realize that there's a good chance it has to do with the age of the software/etc running on windows 10. When I look at cut settings in versaworks, it shows "cut all paths" grayed out. I can't get the machine to connect to the latest versaworks (also running on the computer) as this printer isn't supported but I can get it to print with version 1.1.1. I've tried various file formats that work fine on the SG300. Any tips or thoughts are greatly appreciated!
cornholio
Latest version for SP-540V is 5.51
Don't use transparencies together with cutpaths.
To test, create a path with a spot color CutContour and save it as a EPS.
DAHVID
I'll find a version of 5.51 and see if that helps. The files cut fine on the SG300. Thanks!
Attila Nagy
Special Items should show if a cutline on the artwork. there are 2 reasons for that.
1. there is no stroke coloured SPOT color named CutContour. in your artwork
- Sed me your file. I can check it for you.
2. there is a Bug in VW5. might need to reinstall
- Run VW5 setup as Administrator. and at the First time Run it as Administrator when adding your printer..
