SP300 not printing after damper change
player
Did you draw the ink through the lines and into the damper?
Were you careful to pull off the old damper straight up? The plastic tube the the dampers fit on to are easy to crack, causing lack of vacuum in the system.
Hfuzz132
Had it printing on a test print, then it quit printing. Filled the damper with a syringe and got it going then it quit.
I did not replace the o-ring on the line (didn't have one). Any ideas?
Replaced dampers before with no problems,
sidcon
Hi, Did you find the cause or fix? Does anyone know if the bladder is replaceable on the head and if so where to get them. Im also have issues.
