LowStandards1979
so this is good brain teaser for you roland gurus. i recently have had scan motor errors constantly to where you are basicly just starting up and shutting down the machine. was told that i needed to check tension on cable so i did. it was off a little not much. set the tension at 13. worked about a week and a half and came back. rechecked the tension still at 13. had a 3RD PARTY TECH come by when my boss was here saturday to check/fix problem. He told my boss it was the motor and should be replaced. When i came in monday the machine was worse off than before he touched it. I am not sure exactly what the tech did since i was not present. so when you try to print now it starts up feeds very fast about 10ft or so then trys to print. when you use cut only it will startup cut then feed the media. if you hit sheet cut it will start up feed cutter goes to far left then trys to cut. called the company we bought our printer from (wmplastics) they said to update firmware and replace motor. i have done both with no solution still to my problem.
