My VS-640 is running great, but one thing worries me, when running only 54" wide material (which the printer probably has done most of) the carriage gives a little "squeak" or "squeal" when changing directions at the end of the pass (only on the return pass). When running 64" or other width material it's running silent. I have also gotten some occasional scan motor errors but only very rarely. I've cleaned and lubed the rail with light oil (actually ment for HP rails but it should work) and no change. Is it the bearings, rail, belt or motor? I'm suspecting bearings since it sounds like it's coming from the carriage/rail. Is there anything preventive we can do or do I need to worry at all until it breaks down? It hasn't gotten worse or better with time. Thanx and hope your new year will be great!
