Ziklag
Passion for SignGraphics!
Or, you may consider having the stud-mounting holes computer-drawn in scale (circles sized as mounting hardware) in your graphic's program (CorelDraw, Illustrator, Flexi etc.) . Think in terms that everything involved to doing the "in-scale drawing" in your graphic program is exactly the same when you decide where the mounting holes should be placed in the scaled drawing. Finally, from this completed full scale drawing file you can send to a vinyl cutting plotter to draw, not cut, at full scaled producing a mobile paper template, complete with mounting holes computer-drawn at exact positioning back of the letters, resulting now possessing a paper pattern to take on site for precise stud mount installation. Again, think in terms that this scaled paper template is now the same file that the letters were produced. When on job site simply adhere (tape) the scale paper template to the wall and drill through the visible computer drawn mounting holes also visible from the front of the template. Everything at this point is in position with the actual letters as being one file. Hope that helps.If it's a one-off job and you don't make stud mounted letters on a regular basis, you could do what Gemini did until just the last couple of years. Plot the outlines of the words on pattern paper. Mount short studs on the letters. With the pattern on a slightly resilient surface, hold each letter exactly over its outline on the pattern, then press down, denting the paper with the studs. Draw a cross on each location.
