For Sale Sublimation Bundle: Heat Press INSTA 1020 Heat Press & Mimaki JV300-160 Plus Inkjet Printer $14,750, Sunnyvale, CA
KellyYama
Heat Press INSTA 1020 Heat Press & Mimaki JV300-160 Plus Inkjet Printer Listing is for both machines. Both machines are used but in good shape and functioning - ready to take on new dye sublimation tasks! Dual platens / Small Footprint: Reciprocating dual trays shuttle into the press in a unique way making the Insta 1020 the most productive large format press with the smallest footprint in the industry. Quiet & Simplistic Operation: Press operators appreciate the quiet operation and the ease of learning how to effectively operate our largest press. Production Flexibility: manual, semi-automatic and fully automatic production speeds. Largest Dual Platen:39.41″ x 47.2″ (1 m X 1.2 m). With this press you are ready to GO BIG! Heat Transfers DTF Transfers White Toner Paper Sublimation Vinyl DTG Insta’s 1020 delivers what you need for sublimation and transfer application success: 425 heat, consistent temperature, even pressure & rapid heat recovery. Depth: 107″ (275 cm) Width: 60.5″ (170 cm) Height: 55″ (150 cm) Power: 230 volt, Three-Phase 50/60 Hz, 9kW, 60 Amps JV300-160 Plus 64″ Wide-Format Inkjet Printer Specifics: 64″ Wide-Format Inkjet Printer Print Resolution: up to 1,440 dpi Print Speed: 1,140 SqFt/Hr (105.9 SqM/Hr) Max. Print Width: 63.3 in (1,610 mm) Max. Media Width: 63.7 in (1,620 mm) Fast printing speeds up to 1,140 SqFt (105.9 SqM) per hour – High quality print resolution of up to 1,440 dpi – Choice of eco solvent or dye sublimation ink sets – Nozzle Check Unit and Nozzle Recovery System – 3-way intelligent heater – Reusable and refi llable 600ml ink eco cartridge – ID Cut function enables effi cient cutting operation with the CG-FXII Plus – Ethernet connection – Mimaki Advanced Pass System delivers smooth solids and gradients – New take-up unit design Additional information weight 440 lbs, size 110 × 28 × 55 in. No shipping, door pickup, we are open to offers. Have a forklift to help with loading. PXL_20250630_204550822.jpg PXL_20250630_204600612.jpg PXL_20250630_204607816.jpg PXL_20250630_204612489.jpg PXL_20250630_204619851.jpg
