Summa F dragging across SAV
ysup
Hi.
We're having a problem where our F1612 using the drag module + drag knife tool is intermittently damaging our material. When it's going between cuts, it will sometimes drag across the material without lifting the blade, damaging the job. We mostly use the tool for reflective, in case that's relevant. It's definitely making it an expensive problem.
I played with the tool a little bit in my hand, and it wasn't springing back to the "up" position as easily as I felt it should have. I played with it a bit and now it's going right back (to the up position) when the tool is out of the machine, but the problem on the machine is still happening.
Visually, the spring inside the tool looks good. Our dealer is unresponsive (shout out to DDP/Piedmont!) We've tried slowing down the cutting, but that doesn't seem to affect the speed of the tools between cuts so we're not able to really get a better idea of what's going on.
Any suggestions?
balstestrat
Problem Solver
Have you been using it long? I think Summa specifies it as "consumable" basically with certain life expectancy and then you buy a new one (in case it fails). They don't even recommend to service it if you have problems.
JBurton
Signtologist
That's insane, that module is like $2k and isn't much more than a mounting bracket with a holder for a knife, or does the module contain the actuator for the tool as well? Even then, sounds like the spring is wearing out, is replacing the spring not an option? Could one at least power down the machine when not in use to allow the spring to not sit compressed all the time, extending it's life?
balstestrat
Problem Solver
It has the drag head inside. It always defaults in "up" position so it's not like the spring is pulled all the time.
Now I was thinking but I don't remember what head it has exactly. D and S head is different design.
JBurton
Signtologist
After looking at summa drag knives for a minute on google, I realize I have know idea how they stay in or free spin. The graphtec has shouldered blades that rests against a spring, forcing the cone into the bearings. It's simple, though it relies on the user being able to handle the spring, which I've lost at least once before...
Even after watching a video on a summa blade change, I have no clue what is keeping the blade from falling out, or what the blade is rotating against. I'm curious, but it's not like I need to know...
ysup
the module contains the solenoid
balstestrat
Problem Solver
I think there's a bearing and a magnet inside. But I haven't tore one down.
And also I checked in Summa docs "Drag module is NOT a repairable part". So they won't repair it.
cornholio
There is a linear bearing, a solenoid and a spring. From what you say, you could try a light lubricant on the bearing. I don't think the spring is the problem.
Or
Or it could be the blade falling out of the tool holder... I have seen that on summa roll cutters that use the same holders...
balstestrat
Problem Solver
This 100% i havnt put the drag module in my f1612 since the day it was installed, kiss cutting tool is 1000% better
It's not always true. Drag knife is faster in some cases because it doesn't lift up.
Might make a huge difference if you run a lot of those jobs.
Someone would pay huge money to cut 2-5x faster. Just the right tool can do it.
White Haus
Not a Newbie
And you need the drag tool to remeasure the table surface...
A whole lot of good that actually does.......
I've re-mapped our bed a few times and even then, the depth accuracy/tolerances are insane. It will barely cut through the substrate on one corner and a couple of feet away it will be routing 1/4" into the spoilboard.
Definitely nowhere near any sort of acceptable tolerance for a flatbed cutter/CNC.
balstestrat
Problem Solver
Eh that's not normal by any means. Your unit has a real issue you should get checked out.
