Summa F1612 Not recognizing tools
pepford
Our F1612 is not recognizing any tools. Load a tool, moves to the ADC and stops. Thinking it was the board, we changed it but still the same. Any suggestions what else to check? Any one had similar issue?
Thanks in advance.
cornholio
Could be the sensor in the tandential module not recognizing the barcode in the tool. Does the tool ever turn during initialisation? If not, it's likely the carriage board. If it turns, there is a calibration for the sensor in service mode.
fbert
Look from the bottom part of the tangential module. There is a hole on the metallic cylinder. Rotate the cylinder by hand until you see the sensor. It could be dirty, especially using the pneumatic tool.
ProColorGraphics
anyone ever have a tool not align correctly, so that the tools is not rotated properly to read in the ADC? My rotary knife does this and the frame hits the top of the adc and errors out.
cornholio
There should be a printed and cut piece of thick paper in your accessoires to put on the ADC fixture to calibrate the ADC position. Ask your dealer/service guy.
