Summa + GoSign + Corel acting up
KristianBIS
We prepare files in Coreldraw and send them to GoSign to cut on our Summa S2 T 160 and most of the time it works, however I've had a few instances were the output got jumbled in a way I can't figure out. What makes it extra weird is that it seems to get jumbled the same way everytime.
On the attached we were doing rectangular stickers and as you can see the result is skewed.
Now, all corners and all vertical lines seem to be on the right place, but somewhere along the scan direction it does this weird curve/angle. The file is all straight lines and I've had it happen with other jobs aswell.
On this day I cut several jobs back to back withtout issue, then suddenly when doing this job the issue appears. I do a new print and next try it works out.
Mysterious.
Has anyone ever encountered anything similar and do you dare take a guess at how to eliminate it?
Thank you :)
FrankW
I had that one time because of a printed job label in front of the XY-Line (the black line between the first marker row) deviated the measurements. Perhaps there is some dirt in front of that line which irritates the sensor?
A little bit more white area in front of the line can be helpful too.
jerry369
Try to remove the OPOS XY line in CorelDRAW before sending the job to GoSign so that the plotter does not read it.
KristianBIS
FrankW Hmmm ok, that's interesting - I don't really notice any dirt or the like in front of the line, but perhaps it's simply something that happens if there's not enough area in front of the line. Might be I'm cutting it kind of close and that sort or messes with it. I'll try and pay attention to that in the future, thanks!
jerry369 So remove the line and leave the squares? I reckon precision would be an issue with out the line?
fbert
If the line is too close to the media edge it could be not accurately detected, as media could have small bumps that fool the sensor.
Precision without the line could mainly be affected when media has been printed on high temperature devices as HP latex. YMMV.
KristianBIS
Yes, having the line too close to the edge might be the cause - but what's strange to me, is that I've seen this exact "pattern" on earlier jobs. So it's not so much that the job wasn't cut correctly, it's that it was cut incorrectly in exactly the same way as earlier on other completely unrelated jobs.
I'm going to leave more area in the front and keep and eye on the issues, thanks a lot!
