Summa GoSign Toolbar Corel
SLShop
Something really stupid happened to me. I installed GoSign v4 and spent hours wondering why only the kiss cut, but not the true cut from Corel, was being transferred to GoSign via the GoSign toolbar. After reinstalling Corel several times, I eventually read that v4 is only intended for the Summa S3 series and that all older devices can only use v3. I have a Summa S2, so I reinstalled the older GoSign v3.
Now I have a bigger problem: In CorelDRAW Graphics Suite 2025, the “Send to GoSign” button no longer works. When I click it, absolutely nothing happens. All the other buttons work perfectly fine.
I have reinstalled Corel multiple times, tried manually moving the plugin into the folder via GoSign Tools, completely uninstalled everything using Revo Uninstaller, and reset Corel to factory settings — nothing works. I must have messed something up, and I’m slowly getting desperate.
Has anyone experienced a similar issue before?
JM4Designs
Unless you're my coworker, we just started having the same issue here as well. We've pretty much tried all the same steps with no luck. We're wondering if it was a Windows update or something that broke it. Hoping Summa releases a fix soon.
tobynt
We had the same problem. Installed GoSign Tools 4 (moved to a new PC). Got on the phone with Summa tech support. We got everything uninstalled back to GoSign Tools 3. But, we could never manage to get the "Send to GoSign" on the plugin tool bar to work again after dong this. Said it is probably something Summa would have to fix on the GoSigns tools installer. Currently at V 1.9.2
Currently as of today. No fix from tech support for this issue.
The only work around is to save the file as PDF and open in GoSign 3.
jerry369
It's a Windows bug, when you uninstall GoSign 4 (64bit) and install GoSign 3 (32bit) it does not udpate the register key. You have to manually correct it
Open Regedit.exe (you can find it in the "C:\Windows" folder)
go to: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Summa\GoSign
and change the key InstallDir:
from
C:\Program Files\Summa GoSign\
to
C:\Program Files (x86)\Summa GoSign\
be sure to modify ONLY this key and ONLY the string from "Program Files" to "Program Files (x86)", DO NOT modify any other value in Regedit.
If you don't know how to modify the Windows registry or you don't feel confident, better to contact a technician
SLShop
from
to
The registry entry was set correctly on my system, but you gave me an idea. I reinstalled GoSign v4 again and then uninstalled Corel, GoSign, and GoSign Tools using Revo Uninstaller (including deleting the registry entries and all remaining data). After that, I manually deleted the Corel folder where the toolbar files were stored. I reinstalled everything, and now everything is working again.
Thank you very much!
tobynt
from
to
This worked perfectly for me.
I did not have to uninstall or reinstall anything. I simply made sure to close GoSign 3 and Corel. Made sure to have GoSign 3 installed. Went to regedit and made the fix. Now, the export opens up GoSign 3 and automatically imports my file using the plug in tool bar.
Thank you for the fix!
