SUMMA S ONE KISS CUT CUTTING LIKE FLEX CUT
cyclerc
I DONT KNOW WHY THE KISS CUT PARTS ARE CUTTED LIKE THRU CUT, THE SETTINGS OF FLEX CUT IS OFF IN GO SIGN. THIS START YESTERDAY. WHAT I CAN DO?
jerry369
it would be helpful to know the model of the plotter you are using. in any case, check that Flexcut is not enabled from the plotter panel
cyclerc
SUMMA S ONE D75 LET ME CHECK IN THE PANEL ITS NEW FOR ME THAT. I SELECT THE FLEX CUT IN THE GOSIGN SOFTWARE, IN THE SAVE JOB SOME PARTS ARE KISS OTHER THRU-CUT. THANKS
jerry369
Use Summa Cutter Control program to verify if Flexcut is not active. Verify also that the Sorting Option is off
