freeburgs1235
Hello, I work in the large format department for a company and we recently got a new S3 plotter since our S2 was giving us some issues. We love this new plotter but we are having issues when cutting off sheets. The S2 does not feed the roll when cutting off the sheet, so we just typically lined up the OPOS mark under the head and cut it off. Perfect every time, but with the S3, it advances the roll a little bit, and then cuts it, causing the next copy’s OPOS marks in the roll to be cut off. We have each copy spaced out 3 inches when we print them.
On top of that, when we send our file from illustrator to winplot and ask for multiple copies, the S3 will scan the marks as usual and cut the first copy out perfectly, then it advances to cut the sheet off and depending on what the cut off margin was (we have played with that setting like crazy and the best we have gotten it was to cut halfway between the next copy but not advance to scan the next copy’s marks) it will cut the first copy off, then advance again and cut again, as if it were cutting off the next copy. But it hasn’t scanned or even plotted the next copy. It’s like it just skips scanning it again or trying to plot the next copies and just skips to the cutting it off part. It will repeat the advance, cut process for each copy we ask from winplot. Not sure why it’s doing this… Any help would be appreciated, we were so excited to get this new plotter and this has been a big bump in the road.
