Need Help SureColor S70675 Problem with head 1 light cyan
jbarry14
I am having problems with Light Cyan on head 1. Nozzle check is showing light cyan completely missing. It is working in head 2. No problems with any other colors in head 1 or 2. Have done several cleans and head maintenance. I cant get any light cyan out of head 1. Any suggestions?
jfiscus
Rap Master
I believe the process is called flush & fill, through the menu on the printer. That will purge the head/lines and refill.
Also, check to be sure your caps are seated correctly and the ring has no damage.
jbarry14
I have tried that. No change. I am thinking I will need to replace the head. I can't seem to find much information on replacing a head. But from the parts diagram, it doesn't look to difficult to take apart.
jfiscus
Rap Master
You will need the service program to do the repairs. The repair isn't that hard in itself, but it is impossible without the software.
IIRC - You have to have the software to de-pressurize the head, then to configure the head, then re-pressurize it after install.
