ledbe
The LED Linear Fixtures, max length is 6M and cuttable, comes with magnets, can insert the magnets into the slots and stick the Light Fixtures on the metal or magnetic wall, no need to drill holes or stick double-sided tapes, easy to install and use. there are various types of diffusers with different transmittance. recommend installing high-density chip-on-board COB LED Strips as the light source, the inner width is 15.2mm and allows the max width of LED Strips is 15mm.
Link: https://bit.ly/3XPyWFI
Features:
Includes:
1*LED Linear Fixture
ABS End Caps With Wire Hole/Without Wire Hole
Magnets
Features:
- Model: ALP152
- Material: Extruded Aluminum
- Surface Treatment: Anodized
- Colors: Silver(Default), Black, White
- Size: 18.5*16mm(W*H)
- Standard Length: 1M
- Other Lengths Available: 1.5M, 2M, 2.5M And Max 6M
- Custom Length Available: YES
- Diffusers: PC Diffused Cover, PC Semi-clear Cover, PC Clear Cover, PC Frosted Cover, Prismatic Cover
- Inner Width: 15.2mm
- Max Width Of LED Strips: 15mm
- Max Power: 18W/M
- Beam Angle: 100°
- Tolerance: ±1%
- Magnets Included
- End Caps With Wire Holes Included
- Adjustable Brackets Sold Separately
- 180°, 90°, 90° Vertical, 135° And 135° Vertical Connectors Sold Separately
- Installation: Surface Mounted
- Applications: Wall Or Ceiling Linear Lighting
- 5 Years Warranty
Includes:
Magnets
